Euler model
Old   July 29, 2005, 09:45
Default Euler model
CN
hi,
Fluent manual states that the Eulerian multiphase model in FLUENT allows for the modeling of multiple separate. Does anybody know whether it is possible to define different boundary conditions for each of the phases in Fluent? For example, to simulate a separation process through a sieve, can I no-flux condition for one phase and flux condition for the other?
Many thanks!
Old   July 29, 2005, 18:46
Default Re: Euler model
us
Yes, it is. When u define more than one phase you would see the choices, phase 1, phase 2 , mixture etc. You can set different boundary conditions for each phase.
Old   August 1, 2005, 12:22
CN
thanks for the response.
I wanted to set porous jump for phase 1 (water) and wall for phase 2 (solid particles). However, under boundary condition, the choices (under Type) available for mixture are interior and wall, while only porous jump BC is available for phase 1 and 2. I don't see any other BC choices for phase 1, phase 2 and mixture.
What do I need to do to have more choices for BCs. How do I tell Fluent that I need to use the wall BC for phase 2 in this case? UDF perhaps?
Thank you very much in advance.
Old   August 1, 2005, 13:43
us
Not sure, friend.
Old   August 9, 2005, 06:25
Default different solid layers
Muhammad Ali Akram
How can I define more than one solid phases in the euler model?
Old   August 9, 2005, 12:45
Default Re: different solid layers
CN
Under Deine - Multiphase model - number of phases.
multiphaseInterFoam for RAS turbulence model chiven OpenFOAM Bugs 8 December 6, 2017 02:08
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
MRF and Euler model DropsandSimulations OpenFOAM Running, Solving & CFD 0 September 4, 2009 05:20
multi fluid mixture model issue rystokes CFX 3 August 9, 2009 19:13
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 03:27
