infinitely thin plate
Old   August 5, 2005, 11:13
Default infinitely thin plate
suti
Using Gambitt, is it possible to model infinitely thin solid plate inside a domain e.g. partition inside office, hanging floor inside building? If yes, how? thank you all.
Old   August 5, 2005, 13:14
Default Re: infinitely thin plate
Jason
Yes... Create the volume for the buliding, then create any surfaces that represent the partitions or hanging floors. Then split the volume with these surfaces (make sure the "connect" option is on... this makes meshing, assigning BC's and outputing your mesh easier). When you're defining your BC's just define these surfaces as a wall. You'll also get a 'shadow-zone', but I don't rememeber if this shows up in Gambit, or if it doesn't show up until you import the model into Fluent... what happens is a wall is a single-sided BC (unlike pressure-jump or interior) so in Fluent, the "wall-1" becomes one side of the wall and then Fluent creates "wall-1-shadow" which is the other side of the wall.
Hope this helps, and good luck, Jason
Old   August 6, 2005, 00:14
suti
thank you, jason.
Help with flow past a vertical infinitely thin plate quarkz Main CFD Forum 2 September 19, 2011 05:43
how to mesh a group of thin plate wenlai CFX 0 July 12, 2011 10:23
reversed flow over thin plate qiaomei FLUENT 8 December 30, 2008 03:54
heat transfer on dimpled plate mech FLUENT 4 February 6, 2007 15:15
Parallel Plate Rheometer vs Cone & Plate beginner Main CFD Forum 0 March 19, 2003 11:49
