How to obtain forces
Old   August 22, 2005, 16:55
Default How to obtain forces
Karimu
I am interested in obtaining the forces Fl,Fd,Fmy where Fl=lift force Fd=Drag force and Fmy=Moment about y-axis I know that fluent gives the Cd,Cm and Cl, but I will like if anyone knows how to obtain the forces. Thanks to all
Old   August 22, 2005, 17:25
Default Re: How to obtain forces
Jason
I'm assuming you're talking about when you monitor forces (when you Report->Forces it lists the force and the coefficient).
If you set RHOref=2, Vref=1, Aref=1 and Lref=1 in the reference values window then you'll get forces (check your units though!)
Remember:
F=(1/2)*RHOref*Vref^2*Aref*Coef and
M=(1/2)*RHOref*Vref^2*Aref*Lref*Coef
So by setting the values I gave earlier, you've simplified the formulas to:
F=Coef and
M=Coef
But like I said, double check your units.
Hope this helps, and good luck, Jason
Old   August 22, 2005, 17:26
Karimu
Thanks Jason
Reading forces from previous time step within solver SD@TUB OpenFOAM Programming & Development 5 April 24, 2023 11:51
How to calculate pressure forces using custom field functions? tsagaro FLUENT 7 June 23, 2017 15:45
how to get forces on Iso-Clip Surfaces and How to get forces in cylindrical coordinat CFD XUE FLUENT 3 March 18, 2015 03:28
FORCES don't run! C12Carbon OpenFOAM 0 September 10, 2011 07:34
Valve Forces in CFdesign Mike Clapp Main CFD Forum 3 March 8, 2001 14:09
