Convergence Monitoring
Like Tree1Likes
  • 1 Post By helper
Old   August 8, 2005, 09:40
Default Convergence Monitoring
Jim
Hi All,
With iterative time advancement I can watch convergence of a flow property (e.g. velocity) at a point on a per-iteration basis.
Does anyone know how to do this with non-iterative time advancement (NITA)? I only seem to be able to get a report of the residual after each time step and have no idea what it is doing within the time step itself.
Cheers, Jim.
Old   August 22, 2005, 19:09
Default Re: Convergence Monitoring
helper
With the NITA schemes with either Fractional-Step or PISO scheme, there's no need for the inner iterations (velocity-pressure), hence the name NITA.That's why FLUENT report the resiudals only after each time-step. Yet the NITA schemes preserve the second-order accuracy. The only iterations being done behind the scene are for the individual linearized equations and for the coupled (and non-linear)momentum equations.
soheil_r7 likes this.
Old   August 25, 2005, 12:49
satya
hi helper how to apply this procedure and also do u know about the variable time stepping procedure. thank u in advance bye
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Monitoring Convergence in Stirred Tank using MRF method GOPINATH87 Main CFD Forum 0 August 19, 2011 23:45
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
Monitoring Convergence in Fluent 5.0 Tom Plikas Main CFD Forum 0 April 6, 1999 17:10
