September 5, 2005, 23:40 |
why appear error?
hi,when i compile any code with '#include <udf.h>'in its first line,copmuter always tells me that no such file or directory.why?help me pls!
thanks! |
September 6, 2005, 20:49 |
Re: why appear error?
include what? do you write the name of the file you want to include? is it in the programme directory?
September 6, 2005, 22:59 |
code is following:
#inlude"udf.h" ...... |
September 7, 2005, 03:21 |
OK, if it is written exactly as you have it here then where is the space between the #include directive and the file name. If the file is not in the main directory you can either copy it to the main directory or write the complete file name including the path e.g. <c:\xxxx\xxx\udf.h> In C language the <xxxx> and "xxxx" have different meanings to the parser. Check any C language book for the differenc. Hope that will solve your problem and Good luck
September 7, 2005, 04:52 |
Re: why appear still error?
hi,error still exist. the case is following: #include "C:\FLUENT.INC\FLUENT\fluent6.0\client\src\udf .h" DEFINE_PROFILE(inlet_xv_sinusoidal, /* function name */
thread, /* thread nv) /* variable number */ { face_t f; real flow_time = RP_Get_Real("flow-time"); begin_f_loop (f,thread) { F_PROFILE(f,thread,nv) = 20. + 5.*sin(10.*flow_time); } end_f_loop (f,thread) } Compiling... inlet_xv_sinusoidal.c c:\documents and settings\管理'\桌面\inlet_xv_sinusoidal.c(1) : fatal error C1083: Cannot open include file: 'C:\FLUENT.INC\FLUENT\fluent6.0\client\src\udf.h': No such file or directory Error executing cl.exe. inlet_xv_sinusoidal.obj - 1 error(s), 0 warning(s) why? |
September 7, 2005, 23:05 |
Call your support engineer and if possible post the reason for that, you have forced the compiler to read the file where it is residing, wish happy ending to that situation.
September 7, 2005, 05:04 |
its something to do with your path settings of the header, please ask to fluent support about this, they are best person to advise on this issue.
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
c++ libraries and solver compiling | vaina74 | OpenFOAM Installation | 13 | February 3, 2012 17:43 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
