Modeling porus material
Old   September 14, 2005, 13:32
Default Modeling porus material
Azam Syed
Can anybody help me with defining porus materials in Fluent. Any help in modelling it in gambit would also help Thanks in advance Azam
Old   September 14, 2005, 15:01
Default Re: Modeling porus material
Nishant
Azam, As far as I know, there are two ways to model porous material. One is the porous media, and the other is porous jump. Amongst these two porous jump is simpler to implement and more robust. To model the porous jump, you would need to create a two sided face in Gambit. You can then specify this as a porous jump boundary in Fluent. Porous media a 3d approach where you would specify a fluid zone and then change it to porous zone in Fluent. Please also refer to the help in user manual under boundary conditions.
Old   September 19, 2005, 01:35
Prakash Verma
Yes there are two ways to model the porous media...Porous jump is for 2D and If your porous medium has thickness then use porous media model. In Fluent solver you have to supply viscous and inertial resistance coefficients. To calculate these coefficients refer to the fluent manual.
fluid material setting in evaporator modeling mogoko CFX 2 October 23, 2018 12:12
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Non-linear material modeling in ANSYS jbbose ANSYS 0 January 19, 2010 22:15
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
