October 18, 2005, 03:53 |
How to find Mach Number
Hello, maybe somebody is able to help me with the following problem. Under velocity does not appear Mach Number. Do I have to define Mach Number by myself (custom field function ?)
Thanks Tobias |
October 18, 2005, 04:35 |
Re: How to find Mach Number
Hi, Mach number will appear in the velocity contours if you run the problem with an ideal gas. (materials panel-density). Hope that helps.
October 18, 2005, 09:59 |
Hello dan, thanks. Your tip helped me a lot (now Mach number appears). Thank to you Tobias.
mach number and selection of the fluent solver | turbinesv | FLUENT | 4 | April 24, 2011 00:14 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
Mach number in Post processor | Ramu Maddi | CFX | 3 | August 17, 2007 10:06 |
The Far-field Pressure Boundary & Low Mach Number | Saif-Deen Akanni | FLUENT | 1 | March 5, 2007 05:05 |
how calculate the density in low mach number? | Juhee Lee | Main CFD Forum | 1 | July 31, 1999 15:26 |
