Gambit - hiding geometry?
Old   October 27, 2005, 02:38
Default Gambit - hiding geometry?
Zak
I used four edges in a wedge shape to refine a mesh around a cylinder (2-D), the problem is Fluent treats them as a wall, even when I tell Gambit to leave them as unspecified boundaries. How can I "hide" the geometry in Gambit? I can't delete them since the mesh is dependent on them.
Old   October 27, 2005, 02:55
Default Re: Gambit - hiding geometry?
Manoj Kumar
You may delete the zones which you don't require from fluent's surface>zone>manage(surface) panel.
Old   October 27, 2005, 03:23
Zak
Hi Manoj,
I just found two problems with my mesh, inside the wedge the fluid was unspecified, and I had duplicate edges that made up the wedge. I fixed those problems and it worked! Thanks for your suggestion, I did not know about the zone options in Fluent.
-Zak
[GAMBIT] how to mesh a 3d spiral geometry in gambit seyedashraf ANSYS Meshing & Geometry 9 July 4, 2013 05:42
create turbine geometry with gambit badlaine ANSYS Meshing & Geometry 2 March 26, 2012 23:54
[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry mazhar1613 ANSYS Meshing & Geometry 1 January 11, 2012 23:18
What can I employ to create geometry besides Gambit? summer ANSYS Meshing & Geometry 2 February 11, 2011 14:50
problem about Importing geometry in Gambit Hua Gu FLUENT 3 April 2, 2002 14:24
