mesh skills in gambit
Old   October 27, 2005, 05:25
Default mesh skills in gambit
Fer
Hi everybody!
I'm working with gambit to create 2D and 3D meshes. I'm able to create 2D face meshes from defining the between-node distance of the edges firstly. The problem is that I've tried to define the mesh more acurately in the closer zone near the edge using the tool "define boundary" from the mesh menu, but I'm not able to do it properly. Can anybody explain me the necessary steps to do it in order to connect this finer mesh with the rest of the face mesh?
Thanks
Old   October 30, 2005, 05:27
Default Re: mesh skills in gambit
Mohsen Ghamari
Hi I think your question is not clear but I know that there is not neccessity to use "define boundary" as a tool for meshing the zones close to walls or etc. You can use the conventional tools to define fine or coarse mesh in some zones and "define boundary" is just to simplify your task. Mohsen
Old   November 2, 2005, 02:36
Fer
Thanks Mohsen. Sorry because I said "define boundary" when I wanted to say "boundary layer"
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
How to mesh a circle by Gambit? Zhengcai Ye FLUENT 5 March 24, 2006 01:04
[Commercial meshers] Mesh import from gambit Kaushik Balakrishnan (Balakrishnan) OpenFOAM Meshing & Mesh Conversion 5 April 21, 2005 13:42
3-D Mesh Check in Gambit..... SHR FLUENT 4 March 25, 2003 03:10
