how to patch liquid to an arbitrary zone?
Old   November 16, 2005, 15:45
Default how to patch liquid to an arbitrary zone?
Yi Qu
I use VOF model to track the free surface shape of a rough metal surface when it is melting. The initial surface shape of the molten pool is not regular. In adapt region, there are only three shapes: Quad, circle and cylinder. I cannot patch liquid phase to the region that I want. Any suggestion will be appreciated!! Thanks a lot!
Old   November 17, 2005, 02:23
Default Re: how to patch liquid to an arbitrary zone?
RoM
I think an udf is the only way to do this. You can use a user defined memory to "mark" all the cells (set it to 1 for marked cells and zero for others) you want to patch. Then use the adapt->iso-value panel to mark all cells with udm=1.
RoM
Cyclic Boundary Condition Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Running, Solving & CFD 36 July 2, 2012 12:23
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 02:34
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
