November 15, 2005, 14:11 |
ACCESS_VIOLATION in 3D but not 2D
I have a simple UDF that works great in 2-D. It's esentially a source term that sways a box to simulate sloshing in 2 directions. Things work great until I try to apply it to a 3D case. I follow all the same steps but with a 3D domain and as soon as I try to run it, it crashes:
Updating solution at time level N... done. iter continuity x-velocity y-velocity z-velocity time/iter Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: () Any ideas?!? |
November 17, 2005, 01:43 |
Re: ACCESS_VIOLATION in 3D but not 2D
Please post the source if its not confidential.
RoM |
November 18, 2005, 08:43 |
Hi!
Have you recompiled for use with the 3d solver instead of 2d? /Henrik |
November 18, 2005, 12:51 |
It's an interpreted UDF. Does that make a difference?
