Compile UDF with a C++ compiler
Old   December 7, 2005, 06:24
Default Compile UDF with a C++ compiler
Luca
Hi all! I wonder if it possible to compile a UDF using g++ instead of gcc. I tried to change in the makefile the option CC=cc to CC=g++ but when I compile it gives me some errors related to fluent udf.h file. So the question is: since I have an external library written in C++ how can I link it to my udf which must be written ( I suppose) only in C?Luca
Old   December 7, 2005, 16:19
Default Re: Compile UDF with a C++ compiler
alex
you must compile your C code (not C++). So, you must be sure that you C code is contained in the same folder that your case and date files.
If you are sure about this, you should review the environmental variables on:
control panel/system/advanced options/environmental variables
Here you must write the direction of v1.1 file (this file is contained in program files/C++ files). Click accept, accept and apply.
The last way to compile your UDF is open the VisualC++ toolkit file and run Fluent since here.
Next to it, you can comiple satisfactory your UDF.
I hope that it help you.
Old   December 7, 2005, 20:59
Default Combining C++ code with UDF
Salim
Hi, I have a C++ code and I will combine this code with UDF. Can anyone help me which commands in UDF will use for combining C++ code? Thank you very much
Old   December 8, 2005, 03:25
Default Re: Combining C++ code with UDF
HVN
As I remember and like Alex said, Fluent understand only C and not C++.
The compilers which work with Fluent are listed on www.fluent.com and in the Fluent manual.
HV
Old   December 8, 2005, 05:45
Luca
Dear Alex, thank you for your answer. I have no problem in compiling a UDF written in C. I just wanted to compiled a UDF using a C++ compiler. I can compile my UDF using Visual C or gcc but if I try to compile it as it were written in C++, there are some problems related to how Fluent files are defined. Luca
Old   December 8, 2005, 10:20
alex
dear Luca, I don't know about the solution of your problem, but if I research something about, I inmediately will send a message ok?
Old   December 8, 2005, 11:21
Luca
Thank you Alex! Anyway no problem. I thought of creating a stand alone application written in C++ which is called by my UDF though the operative system. Luca
Old   December 26, 2005, 23:05
owet.L
hi,
I heard that a Chinese guy wrote a code to compile the UDF using C++. You can contact him. His name is Peng Huang. email: huangpeng8@163.com
Good luck. Owet
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
udf compile in parallel system tahereh FLUENT 1 December 9, 2008 09:48
compile the UDF Li Jingping FLUENT 2 April 14, 2003 21:18
