problem with lift curve in airfoil
Old   February 11, 2010, 18:38
Default problem with lift curve in airfoil
thanos
thanos is on a distinguished road
I tried to make the diagram a.o.a v.s Cl for a NACA 0012 airfoil but i have a problem. Even though i have accurate results for angles of attack between 0 and 13, then for greater angles my results are not correct.
More specifically, in a Re=2*10^6 NACA 0012 stalls in a=14 degrees, that means that from that point Cl starts to decrease. However, in my simulations as the angle of attack increases so does the Cl. Does anyone have any idea about what is going wrong?
chord=1m, Re=2*10^6, grid=60000 elements, material=air, u=40m/s, incompressible flow, Spalart-Allamaras viscous model, y+<10
Thanks in advance.
thanos is offline   Reply With Quote
Old   February 12, 2010, 00:42
shakil ahmmed
ahmmed04 is on a distinguished road
try with different mesh for angle 14 or up. As you can increase your boundary distance from the foil,or try with increasing or decreasing the gauge pressure bcos gauge pressure has strong effect on the lift force.
ahmmed04 is offline   Reply With Quote
Old   February 12, 2010, 07:09
thanos
Yes but, in the experiment's report the author doesn't refer to gauge presure, so i guess this should be zero.
Old   February 14, 2010, 00:35
shakil ahmmed
you can increase the boundary distance....best of luck
Old   February 14, 2010, 07:26
thanos
You mean to expand my fluid domain in the y and x directions? This is because flow may have gradients of pressure far away from the airfoil, strong enough to change my exact value of Cl in these angles of attack?
Cheers!
Problem running simpleFoam on a multi element airfoil vinz OpenFOAM Running, Solving & CFD 18 April 11, 2013 11:26
2D Low Speed Airfoil Problem when altering Inlet mike wilson CFX 12 August 3, 2010 11:06
airfoil optimizer chain with drag problem Arnolm OpenFOAM Running, Solving & CFD 2 October 18, 2009 13:43
Zero Coefficient of Lift Problem MH FLUENT 0 February 25, 2007 11:48
solving airfoil like square cylinder problem? zonexo Main CFD Forum 1 May 27, 2006 15:16
