radiation heat transfer in gas turbine burner
Old   December 27, 2005, 07:34
Default radiation heat transfer in gas turbine burner
jarno
I try again to expose you a question about case setting in radiation problem. I'm modelling a solid that is exposed to radiation emitted by methane-air flame. The solid domain and the fluid domain are separated by a couple of surfaces (wall and wall-shadow) that have been originated when I have created a "grid interface" (the two domain have been meshed separately). The questions are: 1- Should the two surfaces be "coupled" for the heat transfer? 2- Is the "internal emissivity" of these two surfaces the solid emissivity? 3- Should I set "partecipate in radiation" for the solid? 4- Should I set 0 the "absorption coefficient" for the solid? Thanks and bests regards
conjugate heat transfer of a turbine blade Steven-GY FLUENT 1 February 23, 2013 14:31
radiation heat transfer sarah l FLUENT 0 August 28, 2010 18:55
Conjugate heat transfer and radiation modeling questions shankara.2 FLUENT 0 April 21, 2009 15:55
radiation heat transfer in gas turbine burner jarno FLUENT 0 December 27, 2005 08:59
heat transfer betwen gas and particle eri andika FLUENT 5 December 8, 2003 18:42
