Splitting Up Volume
Old   January 13, 2006, 11:08
Default Splitting Up Volume
George Gardner
Dear Fluent Chaps,
I am modelling an aircraft for my major research project for Aeronautical Engineering Masters degree and would really appreciate your help!!
I have a volume mesh that is big enough to exceed the max RAM of 2GB. (I am using Linux).
I have gathered from the forum that I should split the volume up into different parts, then re-mesh each volume separately. â€" How do I do this?
Previously I had an aircraft volume subtracted from a cuboid volume to give me one volume to mesh, which worked until I increased mesh density and ran out of memory. I used various size functions.
How should I tackle it now?? I am trying to split the length of the cuboid domain into six smaller cuboids along the length (flow direction), with the aircraft subtracted from the first end cuboid volume.
I had a go at stitching/uniting each volume which seem to be in-appropriate.
If I just left the six cuboids as they are, could I apply a Boundary Condition later on in fluent which is 'invisible' for the walls where each cuboid touches. Maybe the 'Fluid Conditions' BC would work?
Please help me and I Thank you very much for any help.
Regards,
George Gardner
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
