How to start modal analysis
Old   January 12, 2006, 02:30
Default How to start modal analysis
Mvaz
hello to all of u I have a question how to start modal analysis on ansys. can u light on that? pl.
Old   January 12, 2006, 03:22
Default Re: How to start modal analysis
Ahmed
This is not the right forum to answer your question! But if you read the tutorials of Ansys you will get the answer, good luck and cheers
Old   January 12, 2006, 03:51
mvaz
i have gone through the tutorial that given in ansys help but i have a problem how to decide load and how to apply it? thxs
Old   January 12, 2006, 03:56
HVN
You could apply the loads on nodes, surfaces
Old   January 12, 2006, 04:54
Alex Muthaiah
Hi, Eventhough my specialisation is in CFD I can help u Modal analysis is a type of Dynamic analysis where in u r going to extarct natural frequencies of a structure.Required parameters for this is density of the structure and proper boundary conditions. Define number of modes u need extarct(generally first5),method of extraction its better to go for Lanczos method . which gives first 5 modal frequency values after solution the interpretaionis if anyone of the above frequency matches with ur operating one resonance will occur.Pls go through the tutorial of MODAL ANALYSIS OF A CANTILVER BEAM.
regards
Alex
Old   January 12, 2006, 08:33
Peter Attar
It's a modal analysis..ie eigenvalue problem therefore you don't apply loads.
Old   January 12, 2006, 10:58
HVN
What about fixed point or fixed surface?
Old   January 12, 2006, 11:07
Peter Attar
Well if you apply a static load in a nonlinear analysis you can then use the subsequent tangent stiffness matrix generated via the displacement due to this applied load in a modal analysis...but I don't think that is what the original poster was looking for.
Old   January 13, 2006, 03:17
HVN
OK thanks for the information
Old   January 16, 2006, 04:07
mvaz
how do v decide the no of mode to extract and the method to extract? does there any theory regarding this?
Old   January 16, 2006, 08:40
  #11
Alex Muthaiah
Hi I think I have already told u 1)The number of modes depends upon the number of DOF of the systems. So Usually it depends on Client request or generally we got first 6 modes (because we know 6 Dof 3 translate 3 rotary at a particular node).
2)Methods I.Tracking Method. II.Transormation Method. III.Lanczos Method But in Industry we always go for 3rd method.
Refer 3rd method (Lanczos) in detail always good and stable. Also apply proper boundary conditon to extract eigen values, because it also depends on u r Bc's
Alex
Modal analysis of a rotor blade using Ansys mak86 ANSYS 0 July 12, 2011 09:54
Modal Analysis of a Submerged Plate in Water Zhang ming Wu CFX 2 June 29, 2010 08:55
CFD software capable of modal analysis? Jim-gineer Main CFD Forum 4 January 14, 2010 09:29
Modal Analysis - Beta Features - Arnoldi Michael Kolb FLUENT 0 August 8, 2009 13:14
tutorial for CFD & modal (acoustic) analysis ansys workbench 11 badterojan ANSYS 1 June 18, 2009 10:29
