January 23, 2006, 15:41 |
UDF file fix.c
Hi everyone, Has anyone encountered this particular problem before? When i tried to interpret function in udf, it gave me this specific error. Does anyone know how to fix that particular problem? Thank you. cpp -IC:\Fluent.Inc\fluent6.2.16/src -IC:\Fluent.Inc\fluent6.2.16/cortex/src -IC:\Fluent.Inc\fluent6.2.16/client/src -IC:\Fluent.Inc\fluent6.2.16/multiport/src -I. -DUDFCONFIG_H="<udfconfig.h>" fix.c Error: fix.c: line 1: parse error.
Thank you in advance |
January 23, 2006, 20:37 |
Re: UDF file fix.c
I also got the same error but i dont know how to rectify. if u know pls let me know.
January 24, 2006, 02:13 |
Re: UDF file fix.c
February 7, 2006, 02:23 |
Re: UDF file fix.c
Dear sir Please give me mixtank/fix.c and mixtank.mesh. Thanks for your attention. Jafari
February 6, 2006, 12:09 |
Re: UDF file fix.c
got the same problem I'm using Fluent 6.2.16 and don know why the UDF is not working ...
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 | BlGene | OpenFOAM Meshing & Mesh Conversion | 10 | August 6, 2009 04:26 |
[OpenFOAM] ParaView 33 canbt open OpenFoam file | hariya03 | ParaView | 7 | September 25, 2008 17:33 |
[OpenFOAM] Paraview command not found | hardy | ParaView | 7 | September 18, 2008 04:59 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
