January 29, 2006, 08:16 |
Fluent-Monitors-Force
In fluent when i set my drag as a monitor and i begin the iteration no graph gets plotted even though on the x-axis the number of iterations is increasing what could be the problem?
January 29, 2006, 15:49 |
Re: Fluent-Monitors-Force
Hi Sandile,
Perhaps your coefficient is out of range and Fluent don't display it because you do not have enabled the "auto range" option in the display settings of the force you want to monitor. Regards, Freeman |
January 30, 2006, 07:20 |
Re: Fluent-Report-Forces-Drag
Howzit
Ths may seem like a stupid question, but i'm new to this stuff. Could someone please explain to me exactly what the various values that you get in Fluent represent when you hit report forces and you select the vector for drag? the values namely being: Pressure force, Viscous force, Total force, Coefficient of pressure, Viscous coefficient and Total coefficient. which value is the actual Cd? how does Fluent calculate it? P.S. do not be afraid to over-elaborate, im a bit lost Shot Sandile |
problem of running parallel Fluent on linux cluster | ivanbuz | FLUENT | 15 | September 23, 2017 19:12 |
Force Field - Vibrating Immerse Cantilever Problem - Fluent 6.3 | herger | FLUENT | 0 | June 27, 2010 19:50 |
Fluent connection with simulink by TCP/IP | Tanktruck | Fluent UDF and Scheme Programming | 1 | June 28, 2009 12:56 |
define body force (rho* g) in fluent | mohmed | FLUENT | 3 | June 14, 2006 11:36 |
Some help simulating Magnus Force using Fluent | Michele Spinolo | FLUENT | 6 | June 27, 2002 12:57 |
