saving data along a line
Old   February 6, 2006, 09:15
Default saving data along a line
Philip
I want to save data at some discrete points along a line in the domain. I had an idea of defining a surface line and save those data along that. The problem is then that one can only save some avarage, max, min, etc. and not every single value at every single point. Is there a smarter way to do this, than to define every single monitoring surface point?
Regards Philip
Old   February 6, 2006, 15:55
Default Re: saving data along a line
Mark Ratner
you can still save any values you want when you define a line via surface. after you define your line, go into file>export choose your file type, select whatever you named you line from the surfaces menu and then select the value that you want. I export temperature and velocity data into an ascii file which gives every point along that defined line with the values that i ask for. Then I usually bring it in to matlab to process my data.
hope thats what you were looking for.
Mark
Old   February 7, 2006, 03:18
Philip
Thanks a lot, but I'd like to save automatically at certain times during computations. Is that also possible?
Philip
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
1.7.x Environment Variables on Linux 10.04 rasma OpenFOAM Installation 9 July 30, 2010 04:43
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
Data saving in Fluent Endee FLUENT 2 September 14, 2005 09:55
