combustion -pressure ?
Old   February 4, 2006, 05:23
Default combustion -pressure ?
abel
Hello, I am simulating a h2 /Air diffusion flame in a gas turbine combustor under 1 Mpa pressure. please where to introduce 1Mpa ( prepdf, operating pressure in flunet ?).
Thank you
Old   February 4, 2006, 14:13
Default Re: combustion -pressure ?
balmiki
hi able
u can specify 1Mpa at inlet BC.
Old   February 5, 2006, 01:34
Ynot
In prepdf, you have to set the pressure for the fuel and oxidizer.
These will be automatically used as the operating pressure (once you hook the pdf file to fluent, you will not be able to modify the operating pressure, you will see that the operating pressure box is disabled)
Old   February 5, 2006, 10:47
abel
Hi balmiki My bc are velocity inlet type, no pressure field is available ???
Old   February 5, 2006, 14:21
balmiki
if pressure at the fuel and oxidiser inlet available try the problem while converting velocity inlet to pressure inlet.
Maintaining Static Pressure at Fluid Flow Inlet cdevalve FLUENT 3 January 14, 2012 00:11
Oil combustion brajh11 CFX 0 March 8, 2011 16:55
Setup/monitor points of pressure and force coefficients siw CFX 3 October 22, 2010 06:07
Help ASAP! pressure inlet & outlet engahmed FLUENT 0 June 13, 2010 15:33
FLOW AROUND A PLATE_NEGATIVE ABSOLUTE PRESSURE???? tania FLUENT 11 March 23, 2004 08:51
