cyclone geometry help
Old   February 15, 2006, 19:23
Default cyclone geometry help
ANJUM NAVEED
hi i am very new to CFD and working with fluent on cyclone. i made cycone geometry in gambit and now having problem in messhing it.i made geometry with top to bottom approach that is by volumes and i did subtraction boolean operation to creat vortex finder. now maybe my approach is wrong and should i apply bottom to top appraoch because i can not mesh it i tried different combination for messhing. second i want to know that if i mesh all the faces then will it work or i have to mesh volume for applying model. any suggestion please and if anybody can provide me with some tutorial on cyclon or any example i will apreciate. my email address is anjumnaveed76@yahoo.com thanks Anjum
Old   February 16, 2006, 16:32
Default Re: cyclone geometry help
freeman
hey boy you wonna do some trial and error then check your mesh quality before exporting it.
start meshing the small volumes and proceed to the larger volumes. the danger here is that at times gambit ignore your parameters and set its own based on the earlier mesh size. if cooper doesn't try tet. Read the gambit tutorials and manual too.
all the best!!
Old   February 17, 2006, 03:27
ANJUM NAVEED
hi by saying the mesh small volume and then go to bigger one does it mean that i can devide a big volume in smaller ones or i have to creat a geometry with smaller volumes as i told i did different boolean operations with different volumes and at the end i have only one big volume. can u suggest any good approach.
Cyclone Geometry in Gambit Rajesh Kumar Main CFD Forum 4 July 7, 2012 06:07
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 19:42
[Gmsh] Problem meshing an imported geometry Alicia OpenFOAM Meshing & Mesh Conversion 0 March 30, 2010 04:53
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 08:17
vitual _ real deneb FLUENT 3 January 22, 2007 04:31
