February 23, 2006, 02:50 |
Re Number
Hi, I am a little beat confused with Re Number. I have an inlet pipe with a D diameter. This pipe is connected with a valve, in which moves a piston. Now my question. Should I evaluate my Re number with inlet pipe (eg. with D diameter), or should I take into account the piston opening? In the last case, Re number is fully dependant of piston opening, and describe much more the flow characteristics. Any Advice? Thanks a lot.
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 10:37 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
