March 7, 2006, 16:53 |
Accelerating 2d Aerofoil
I am not awear of any resources on the net or in fact anywhere on this subject.
Basically using a UDF I am simulating an accelerating flow, so the inlet velocity being a function of time, fluent is confused to provide something of a smooth acceleration via the time step being small (I have found t = 1e-4 is sufficient), I am interested in the steady acceleration but fluent does not simulate the acceleration as I would expect, taking somewhere in the region of 0.5 seconds of flow time to reach the desired acceleration and 1.5 seconds for transients to decay due to the increasing acceleration. This is a significant amount of time using a desktop computer and showing a property I would rather ignore at this time. I would be interested if there was away of fluent solving the required acceleration at the start to avoid the occurrence of transients. The graphs should give an indication to my problem. http://www.umsu.manchester.ac.uk/hik...celeration.jpg http://www.umsu.manchester.ac.uk/hik...C/Other/CL.jpg The fuzziness in the CL graph is due to the rate of acceleration constantly changing slightly but oscillating around the desired value. Any help would be greatly appreciated thanks Iain Cartwright |
Meshing aerofoil | Sajal Sengupta | FLUENT | 0 | June 19, 2006 05:08 |
digitizing an aerofoil/ meshing problems | Simon | FLUENT | 2 | February 27, 2006 11:18 |
Fluttering or Vibrating aerofoil | Alan | FLUENT | 1 | January 13, 2006 03:06 |
Meshing an aerofoil with a plain flap | Fatou | FLUENT | 0 | November 15, 2005 14:24 |
2D Aerofoil Simulation | StudentAndrew | CFX | 10 | October 28, 2005 16:15 |
