LAMINAR MULTIPHASE FLOW
Old   March 6, 2006, 07:42
Default LAMINAR MULTIPHASE FLOW
Jaroslav kotara
I'm working in the field of glass industry focused on laminar bubble flow in the high viscous liquid (glass melt). I'm a newcomer in Fluent. Can anyone how to model this multiphase task appropriatelly? I am mainly interested in the flow of one single bubble and its size change during rising up to the glassmelt surface due to the pressure gradient. The practical usage of this model is for knowing the growth velocity of bubbles released by refractory material corrosion during melting in the glass furnace. Which of VOF models is most suitable? Which B.C. shall i use?
Old   March 7, 2006, 02:21
Default Re: LAMINAR MULTIPHASE FLOW
akharicha@hotmail.com
Yes you should use VOF, but it is not easy for an amateur... There are 3 or 4 VOF methods available in FLUENT, the best is georeconstructor...but it is also the hardest to handle...
I advise you to use a mesh which resolves correctly your bubble curvature...
keep in touch
Old   March 7, 2006, 08:20
Jaroslav Kotara
In my opinion this can be modeled very simply by means of VOF. I tried to define viscous glass melt as a 1st phase and air as 2nd one and also set surface tension. What i still dont know is how to avoid the overpredicted diffussion of the gas into the glassmelt and loosing the exact shape of the interface.
I would most likely achieve the settings under which the bubble remains smooth and entire along the unsteady test time line according to the real beahaviour. Does anyone have experience with that?
Old   March 8, 2006, 03:24
Diffusion is proportional to the grid size, so use a grid size AS SMALL AS POSSIBLE. 4 cells within the interface gives good results. High order scheme for the interface tracking...and I have no visible diffusion of the interface...
Convergence of laminar flow model for high Re Chander Main CFD Forum 0 December 16, 2010 05:10
Disturbed flow field at outlet boundary (Multiphase flow through pipe) Michiel CFX 17 April 21, 2010 10:14
Laminar flow and roughness in fluent?? 1000sh FLUENT 0 April 16, 2010 14:42
Modelling roughness with a laminar flow in Fluent 1000sh Main CFD Forum 0 April 16, 2010 14:41
Laminar flow mech FLUENT 4 February 1, 2007 14:18
