Error while running in PARALLEL
Like Tree3Likes
  • 1 Post By Ravi Duggirala
  • 1 Post By step
  • 1 Post By dokeun
Old   March 15, 2006, 00:07
Default Error while running in PARALLEL
Ravi Duggirala
Hello friends,
I am running a 3D case in parallel using Fluent on 30 nodes. I ran a case (Eps-0.41.cas) in the morning and it ran well. Again I ran the same case in the evening and I got this error. I am seeing this error quite often when I run in parallel. We are using BEOWULF cluster. Error is as follows
Emergency: received SIGHUP signal.
The application is busy. Please wait a moment.
: Emergency: received SIGHUP signal.
: Error: = (equal): invalid argument [1]: wrong type [not a number] Error Object: #t
> invalid command [yes]
> Halting due to end of file on input. parent: Failed to read len_buf
Please anyone who have some idea, help me... I badly need your help...
Thanks Ravi
jzc likes this.
Old   August 2, 2010, 04:57
Default same problem
Dokeun, Hwang
dokeun is on a distinguished road
I got a problem maybe the same as Ravi's.
Stack backtrace generated for process id 23031 on signal 1 :
fluent[0x4b68aa]
/lib64/libc.so.6[0x353e2302d0]
/lib64/libc.so.6(__select+0x62)[0x353e2cced2]
fluent(listen_input+0x1c2)[0x4b97b2]
fluent[0x4ba025]
fluent(lreadf+0x2d)[0x5705dd]
fluent(eval+0x7cc)[0x56b8dc]
fluent(eval+0x125b)[0x56c36b]
fluent(eval+0x906)[0x56ba16]
fluent[0x56cd58]
fluent(eval_errprotect+0x32)[0x56cde2]
fluent(eval+0x2ef)[0x56b3ff]
Please include this information with any bug report you file on this issue!
No error handler available
Is anybody who has the answer?
dokeun is offline   Reply With Quote
Old   August 2, 2010, 09:55
step is on a distinguished road
Hello Dokeun,
I made the experience that it sometimes helps to read in the case on a single processor. Afterwards partition it manually for, let's say 30 knots, and then save the case and read in parallel. Sometime it helps, because it appears to me that the autopartitioning feature is not as "stable".
Best regards
jzc likes this.
step is offline   Reply With Quote
Old   August 2, 2010, 19:50
Default Thank you
Dokeun, Hwang
Thank you for your advice, step
I think I will try it =)
Originally Posted by step View Post
Hello Dokeun,
Best regards
Dear step
It works. After 1 iteration with single processor, I ran the case in parallel.
Thank you so much again.
jzc likes this.
Old   August 3, 2010, 10:01
I'm happy that I was able to help. You are always welcome!
Best regards
Running mapFields with Parallel Source and Parallel Target RDanks OpenFOAM Pre-Processing 4 August 2, 2016 05:24
Running dieselFoam in parallel. Palminchi OpenFOAM 0 February 17, 2010 04:00
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 09:38
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 07:52
running multiple Fluent parallel jobs Michael Bo Hansen FLUENT 8 June 7, 2006 08:52
