March 23, 2006, 23:31 |
Forcing a Grid
I want to check the flow around a cylinder for the case of a cartesian mesh around the cylinder. Is it possible to force fluent to generate cartesian mesh around the cylinder.It does not matter if the cells are degenerate.I tried to generate the mesh and it generates a complex unstructured mesh.Is there a way to force a structured mesh around the cylinder.
-H |
March 23, 2006, 23:41 |
Re: Forcing a Grid
yes. it is easy . in fact very easy................
just divide the whole domain into 2 or 4 parts and make the one vertex of each face as side and force the map mesh |
March 28, 2006, 08:17 |
Re: Forcing a Grid
even you can split the circumference of cylinder in to four parts and u can mesh outer domain as you want
bye |
MapFields to New Grid For Extreme Grid Deformations due to Body Motion | albcem | OpenFOAM | 0 | May 5, 2009 14:17 |
Grid Adaptation | Suresh | FLUENT | 0 | October 15, 2003 13:18 |
GRID TO GRID INTERPOLATION in FLUENT | calogero | FLUENT | 3 | June 4, 2003 08:32 |
Combustion Convergence problems | Art Stretton | Phoenics | 5 | April 2, 2002 05:59 |
Troubles modelling flow through a grid | Hans Klaufus | CFX | 1 | June 28, 2000 16:43 |
