standard Vs PRESTO! scheme
Like Tree22Likes
  • 21 Post By aliabadi
  • 1 Post By Baran
Old   March 25, 2006, 09:53
Default standard Vs PRESTO! scheme
parag
If one uses standard pressure interpolation scheme & for same problem with same all other settings except now PRESTO scheme is employed then converging answers should be same or there will be a huge differnce in answers?
Old   May 20, 2010, 12:58
Default Differences Between PRESTO! and Standard Pressure Discretization
Amir Abbas Aliabadi
aliabadi is on a distinguished road
To discretize momentum equation, one needs pressure values on the control volume faces.
Standard pressure discretization interpolates the pressure on the faces using the cell center values. On the other hand PRESTO! discretization for pressure actually calculates pressure on the face. This is possible using staggered grids where velocity and pressure variables are not "co-located".
PRESTO! discretization gives more accurate results since interpolation errors and pressure gradient assumptions on boundaries are avoided. This scheme works better for problems with strong body forces (swirl) and high Rayleigh number flows (natural ventilation). PRESTO! however, is more computationally costly, since you need more memory for "alternate" grids.
For example when you solve natural ventilation flows using standard discretization, you assume zero pressure gradient at the wall which gives erroneous velocities at the boundary, but if you use PRESTO! you account for pressure gradient at the boundary and get the correct answer.
aliabadi is offline   Reply With Quote
Old   August 23, 2010, 08:09
Smile Reference
A
Ronnfors is on a distinguished road
HI!
I am currently studying different pressure schemes for multiphase flows. I try to motivate Fluent recommendation on using PRESTO!.
May I ask if you have a reference for what you wrote?
Thanks!
Ronnfors is offline   Reply With Quote
Old   August 23, 2010, 14:16
Default Reference for PRESTO scheme
Amir Abbas Aliabadi
Here is a reference for PRESTO! scheme
Peyret, R., 1996. Handbook of Computational Fluid Mechanics.
Academic Press Limited, USA.
Good Luck
Old   August 24, 2010, 02:26
Smile Thanks!
A
Great! Thanks!
I tried to find in Tannehill, Versteeg, Pantakar but no luck in those books!
BR
Andreas
Old   August 13, 2013, 23:01
Baran is on a distinguished road
Hello there,
I wondered which section explain the PRESTO method?
I was not able to find it in the book?
Thank you
Baran
Andrea159357 likes this.
Baran is offline   Reply With Quote
2nd order upwind scheme (Fluent and CFX) Far FLUENT 0 May 22, 2011 01:50
Standard discretization scheme Salwan FLUENT 1 February 22, 2007 18:24
extrapolation in MUSCL scheme Chandra Main CFD Forum 6 February 14, 2007 11:21
Presto scheme Christian FLUENT 0 April 14, 2003 03:49
Standard for checking and testing numerical schemes? X. Ye Main CFD Forum 7 August 31, 1999 17:05
