March 31, 2006, 10:35 |
How can I monitor pressure at a point?
Hello, I'm doing unsteady calculation and I want to monitor the pressure at a fixed point for each timestep. How can I do that in fluent? Thanks.
March 31, 2006, 23:20 |
Re: How can I monitor pressure at a point?
1 difine point:surface--point(input cordinates of point wanted) 2 solve--monitors--surface--fill your information to dialog table(to choice "pressure" under report...
April 1, 2006, 02:53 |
Thanks a lot man!
April 5, 2006, 22:35 |
Hello, I followed your steps but the static pressure is always 0. What should I choose for 'Report Type'? I chose 'Integral'. Thanks again.
April 7, 2006, 11:44 |
Choose area weighted average. Also save the values at every time step, not every iteration.
April 8, 2006, 09:05 |
Thank you!
July 6, 2015, 01:22 |
freeday
I want to monitor a pressure at a point which attached in moving wall. How can I make this point moving together with the wall?
March 4, 2016, 07:25 |
Halewijn Wayenberg
I know this is an old topic, but I actually want to do the exact same thing as freeday but haven't been able to find a solution for it. Isn't there is simple way to move your monitor? |
September 26, 2016, 07:06 |
Hello All,
Rajendra Kumar
Rep Power: 12 |
I have extracted the pressure as mentioned above but unfortunately pressure value is not matching with the experimental value with similar wave characteristics. More specifically, I am interesting in dynamic pressure.
Can anybody help me to find out the exact reason Thank you in Advance! |
block-structured mesh for t-junction | Robert@cfd | ANSYS Meshing & Geometry | 20 | November 11, 2011 04:59 |
Problem with UDF compiling for kTkLW model | Wantami | FLUENT | 0 | July 18, 2011 05:11 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
[Gmsh] Gmsh and samplesurface | touf | OpenFOAM Meshing & Mesh Conversion | 2 | December 10, 2007 02:27 |
