Macro to get Thread/Zone Name
Old   March 29, 2006, 19:13
Default Macro to get Thread/Zone Name
Abhijeet
I'm trying to get the face name using the Macro THREAD_NAME(t). The UDF compiles but when I execute it, the Macro does not return me the face name. THREAD_ID(t) and THREAD_TYPE(t) work as they should.
part of code with the above macro usage
char *name; thread_loop_f(t,d) { name = THREAD_NAME(t);}
Suggestions please. Thank you Abhijeet
Old   March 30, 2006, 03:11
Default Re: Macro to get Thread/Zone Name
Luca
It doesn't work...I get a serie of numbers instead of the name...Luca
Old   March 30, 2006, 11:59
Abhijeet
ok, any workaround that your can suggest ....Abhijeet
Old   March 30, 2006, 13:30
Allan Walsh
Set up your case. Look at the integer corresponding to a certain thread. Go back to your UDF and type in the integer.
Yes, it is crude, but without any help from FLUENT programmers, it seemed a reasonable compromise.
Old   March 31, 2006, 11:15
Abhijeet
Thanks Allan, cant really do that have about 1500 FACES !!! The whole purpose of the UDF is to automate the calculations at the end of a simulation, apply the changes and then reiterate.
Macro Problem!!! eRzBeNgEl STAR-CCM+ 3 August 9, 2011 02:04
Macro Trouble -Winows Explorer Crashes with Macro Martin Castillo FLUENT 1 July 25, 2007 04:18
Macro problem cfddummy Siemens 1 April 9, 2007 12:37
macro not function! guang ai Siemens 0 July 25, 2004 18:53
Call a macro from a macro Flav Siemens 2 July 1, 2004 05:42
