temperature
Old   April 17, 2006, 02:29
Default temperature
mech
hi I have simulated compressible isothermal flow with ideal gas law in a microchannel. gas velocity and pressure is low. I put input and wall temperature 314k. But when I calculate total temperature of gas its temperature is over 314 though the increament is very small. Is it realistic. CAn any body clarify the matter. I found static temperature 314k. Thanks
Old   April 17, 2006, 10:44
Default Re: temperature
Chandra Murthy
Fluent coupled solver solves the energy equation combined with flow equations, even though u switch off the same in the panel. when u solved compressible flow, if the flow has finite velociy, definitely there will be positive difference of (To-Tsta).
Problem with zeroGradient wall BC for temperature - Total temperature loss cboss OpenFOAM 12 October 1, 2018 06:36
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
monitoring point of total temperature rogbrito FLUENT 0 June 21, 2009 17:31
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 00:07
