April 20, 2006, 20:21 |
Exporting BC's from one case file to another
Thanks for your interest in reading my question. Do you have any idea how we can copy/export the boundary conditions of a case file to another case file? I am asking this because when I make a modification in the geometry or the mesh and I import it in FLUENT, I need to define again all the boundary conditions which can be pain. Thanks, Mazyar |
April 21, 2006, 02:04 |
Re: Exporting BC's from one case file to another
Itīs possible about the text-user interface.
The comand to export : file write-bc nameofbc The comand to import file read-bc nameofbc |
April 21, 2006, 12:40 |
In text UI, type File. Then type write-bc Then input temporary filename, ex: bc-example All material properties and BC will be saved on file you typed above.
Open new cas file. type file then, type read-bc then type temporary filename that you used. ex: bc-example. Then, all BC and material properties you saved will be loaded on your new cas file. Thanks |
April 22, 2006, 05:03 |
it is a good advise i have benefitted. i also have a question related to this, when i do some modification in a geometry and read the case in fluent, i find the zones and id change. how do i keep the zones and id's same in new case and apply the old bc's.
Thanks for your reply. |
Changing the grid on the same set-up | Katya | FLUENT | 7 | October 8, 2009 16:31 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
