Meshing geometry
Old   May 1, 2006, 10:18
Default Meshing geometry
Hengky
Hi folks, I was wondering if you could help me with this problem ERROR: Splitting of existing meshes on a source face (face 59) is not implemented yet. Does anybody know how to solve this particular problem? Thank you so much in advance
Old   May 3, 2006, 17:59
Default Re: Meshing geometry
J.Gimbun
what are you trying to do? hybrid mesh? or splitting your domain with interior to generate hex mesh. Or you might trying to mesh (with hex) a domain with either source is on splitted face and another one is single. It easy, just split the other face in the similar way (with the first one) then mesh them. I'm very sure this will work, because I have the same problem long time ago. regards, Jolius
[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry mazhar1613 ANSYS Meshing & Geometry 1 January 11, 2012 23:18
Need help on meshing this simple geometry nha1g08 ANSYS Meshing & Geometry 3 March 9, 2011 02:13
Meshing on simple geometry pukiwawa FLUENT 5 August 31, 2008 12:04
Problem meshing turb. blade tip clearance geometry Balu FLUENT 0 June 7, 2008 21:10
meshing geometry in gambit soundar FLUENT 1 January 7, 2005 02:59
