n_uds error
Old   May 4, 2006, 09:39
Default n_uds error
Nathan
Hi all,
I have included the header file 'models.h' into my UDF and am using n_uds to check that the scalar has been defined. Every time have interpreted the file I get this response:
Error: C:\models\anode.c: line 172: label "n_uds" not found (pc=8768)
I'm baffled by this one!
Cheers, Nathan
Old   May 4, 2006, 15:28
Default Re: n_uds error
Aidan
did you use N_UDS in capital letters?
Old   May 5, 2006, 04:37
Nathan Molyneaux
Hi Aidan,
I have tried both the lower case and higher case versions and there does not seem to be a change.
Nathan
Old   September 16, 2015, 10:56
Maryam-A is on a distinguished road
How did you solve the problem.
I have the same problem.
I would appreciate if you can help me.
Maryam-A is offline   Reply With Quote
Old   September 16, 2015, 11:03
Bruno Machado
Bruno Machado is on a distinguished road
First you need to enumerate them.
enum
... your UDS...
NUM_UDS
Then later you can use NUM_UDS.
Bruno Machado is offline   Reply With Quote
Old   September 16, 2015, 13:32
Thank you for your reply.
But I used enum for specifying my user scalar,too.
enum
alpha,
N_REQUIRED_UDS
do you have any other idea for me?
Old   September 16, 2015, 13:48
Actuly these are my program's error after a part of my udf:
enum
alpha,
A,
B,
N_REQUIRED_UDS
DEFINE_ADJUST(alpha_adjust,d)
Thread *t;
cell_t c;
if(N_UDS<N_REQUIRED_UDS)
Internal_Error("not enough user-defined scalars allocated");
line 316: label "n_uds" not found (pc=18).
line 316: function "internal_Error" not found (pc=50).
Old   September 16, 2015, 15:24
Bruno Machado
enum
alpha,
A,
B,
N_REQUIRED_UDS
Thread *t;
cell_t c;
Got this piece of code in the internet. Try to use DEFINE_ON_DEMAND or DEFINE_INIT instead of DEFINE_ADJUST.
#include "udf.h"
enum {
VORT_Z, /* Index of UDS: VORT_Z=0 */
N_REQUIRED_UDS /* # of UDS variables: N_REQUIRED_UDS=1 */
DEFINE_ON_DEMAND(vortz_on_demand)
Domain d; /* domain is not passed in */ Thread t;
cell_t c;
face_t f;
/* Make sure there are enough user-defined scalars. */
if (n_uds < N_REQUIRED_UDS) {
Internal_Error("not enough UDSs allocated");
Old   September 17, 2015, 01:38
Hi
Thanks for your response.
I tried this function but still doesn't work.
I 'm wondering if I have mistake about using UDS.
I have 3 uds, 1 is for volume fraction transport equation of nanoparticle, and 2 others I use only for calculating temperature gradient and consequently calculation Laplacian. I want to use them as scalars.
Old   September 17, 2015, 01:46
Hi
Old   September 17, 2015, 05:01
Bruno Machado
Hi
I tested and the code worked. Did you set the scalars in the Fluent menu? I mean, Define... User define... Scalar... Try it in the DEFINE_INIT instead of the EXECUTE_ON_DEMAND and hook it.
Old   September 17, 2015, 09:23
Yes I set it and checked the number of scalars in fluent by export-solution data,too.
my English is weak that's because I cant explain my code enough.
At first I used property of material like viscosity and ...
and then I used enum and adjust for udsi.
all the macross are in 1 udf by #include"udf.h" and #include "sg.h" headers.
Old   September 17, 2015, 09:33
As you said alpha is index of my first UDSI(C_UDSI(c,t,0)),
so I have only one Adjust function (Adjust_alpha),
but I have 3 scalars, Is it true?
Old   September 17, 2015, 09:57
Bruno Machado
This part of the code should not be placed in the ADJUST macro. Put it in the INIT macro.
But to be honest with you, for the small piece of your problem I know, this is something that does not affect your code at all. If you are not sure how to implement it now, make your code work and later you try to implement this part.
Old   September 18, 2015, 00:27
Thank you for all your responses.
I did it and have this error "Divergence detected AMG solver-Temperature"
Old   September 18, 2015, 05:25
Bruno Machado
well, this is something else. Not related with this part of the code at all. Check your under relaxation factor to see if your problem can get convergence.
Old   September 20, 2015, 11:57
I changed one part of my code but this time I face this error
" received a fatal signal error"
I even can not initialize my code any more!!!!!!!!!!
I need help
If you give me some advice , I would appreciate it.
Old   September 20, 2015, 12:21
I found the error is because of wrong boundary condition UDS on the wall.
This is my B.C udf:
DEFINE_PROFILE(alpha_bc1,thread,position)
Thread *t;
cell_t c;
begin_f_loop(f,thread)
C_UDSI_G(c,t,0)[0]=-(D_T/D_B)*C_T_G(c,t)[0];
F_PROFILE(f,thread,position)=C_UDSI_G(c,t,0)[0];
end_f_loop(f,t)
Old   September 20, 2015, 12:28
As you see I wanted to return C_UDSI_G(c,t,0)[0] .
It means I wanted to return derivative of UDS as wall boundary value.(volume fraction)
Is it right?
Old   September 21, 2015, 04:41
Bruno Machado
This is my B.C udf:
Thread *t;
cell_t c;
end_f_loop(f,t)
here you did not initialized the face_t f.
I think the way you are defining the gradient is not the best way to do it. create a profile that returns the value you want for the gradient and in the boundary condition panel in fluent, you can set as a gradient profile using the profile you created. Be careful once you are working with faces and not cells, your macros should not contain cells.
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 17:43
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
user defined function cfduser CFX 0 April 29, 2006 10:58
