LES in 2D
Old   May 24, 2006, 04:14
Default LES in 2D
Q
Can I use Fluent to do LES in 2D?
Thanks for answering Q
Old   May 24, 2006, 04:27
Default Re: LES in 2D
Peter
Yes, there is a TUI command to enable that. Please try and search this forum using the keywords LES and 2D.
Old   May 25, 2006, 11:29
Alberto Leon
El comando para activar el LES en 2D es (rpsetvar 'les-2d? #t). The command for activating the Les in 2d is (rpsetvar 'les-2d? #t).
Fuente: Source: http://www.fluent.com/software/unive...Tui_Scheme.pdf
Old   May 26, 2006, 09:52
Dave
There was a long discussion about LES in 2D on before on one of the cfd-online forums, it's worth reading - better still some text books on LES. It is not valid to run LES in 2D. Because LES does not model turbulence it resolves it, and turbulence is inherently 3D, 2D LES will produce an answer, but not the right answer (if you do get the right answer, it's by luck only).
If you're doing it just to find out if the model runs, then fair enough. If you're going to present the results then do some more homework. If you presented 2D LES results to me, I'd tell you you'd wasted your time and to come back when you've run them in 3D.
Turbulence dampening due to magnetic field in LES and RAS eelcovv OpenFOAM 0 June 8, 2010 11:35
LES grid mesh L3munoz Main CFD Forum 0 April 7, 2010 05:05
LES and combustion model Margherita Cadorin CFX 0 October 29, 2008 05:24
Differences between a laminar code and a les one ben Main CFD Forum 9 February 16, 2005 23:40
Some Questions about LES. Bin Li Main CFD Forum 2 February 20, 2004 09:58
