May 27, 2006, 17:04 |
Error when loading a shared library
Hi I got some problems loading a parallel udf. When I try to compile the udf, averything works well, but , when I load it I got this error therfore i can't open my old file case and dat
********************* oapening library "libudf"... Primitive Error at Node 1: open_udf_library: No such file or directory Library "libudf/lnx86/3ddp_host/libudf.so" opened inlet_x_velocity ***************** thank you for your help |
May 27, 2006, 19:39 |
Re: Error when loading a shared library
If you used a fluent parallel session such as 'fluent 3ddp -t2' to build your UDF before (when you used the old case and dat files), then you will also need to start a parallel session now, before reading your case and data files.
May 29, 2006, 11:57 |
Hi, i used a fluent parallel session fluent 3ddp, i build my udf before reading my case and data files.the Udf is build with success. but when i read case and data file tje same error appears:
Opening library "libudf"... Primitive Error at Node 0: open_udf_library: No such file or directory Library "libudf/lnx86/3ddp_host/libudf.so" opened please help me |
May 29, 2006, 13:47 |
Are the two machines of the same architecture (i.e. both are 32 bit or 64 bit)?
May 29, 2006, 14:51 |
i used a machine with 32 bits
problem loading UDF library in parallel cluster | Veera Gutti | FLUENT | 8 | July 26, 2016 07:24 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
BEGINNER: error while loading shared libraries | ka1184 | OpenFOAM | 3 | February 19, 2010 07:11 |
error while loading shared libraries: libelf.so.0: cannot open shared object file: No | esmailpour | OpenFOAM | 7 | October 15, 2009 07:09 |
OpenFOAM141dev linking error on IBM AIX 52 | matthias | OpenFOAM Installation | 24 | April 28, 2008 15:49 |
