UDF error : DEFINE_PROPERTY with PDF Model
Old   June 2, 2006, 17:07
Default UDF error : DEFINE_PROPERTY with PDF Model
Abhilash Chandy
I compiled and built a DEFINE_PROPERTY to calculate a customized density for a simulations where I am using the Composition PDF Transport model as the combustion model. It compiled and built without any problems.
However while running the code for a non-reacting case it gives me the error
" Error: get_udf_function: function calc_density::libudf has wrong type: 44!=2 "
I know this usually happens if you hook the UDF at the wrong place. Currently it is hooked at the 'Materials properties' panel for density. I tried something else though, I changed the combustion model from 'Composition PDF Transport' to 'Species Transport' and it began to work.
Anyone knows why the DEFINE_PROPERTY for calculating density is incompatible with the composition PDF transport model. Any help is greatly appreciated. Thanks, Abhilash Chandy.
A question about UDF utility in mixture and multiphase model aleisia Fluent UDF and Scheme Programming 0 June 7, 2011 16:32
UDF for Herschel-Bulkely model emad Fluent UDF and Scheme Programming 5 July 20, 2009 08:16
UDF for the mixture model khar nab FLUENT 0 July 31, 2008 06:29
About Composition PDF Transport Model cfdfans FLUENT 0 October 25, 2004 06:00
