problem with running UDF in batch mode
Old   June 6, 2006, 06:49
Default problem with running UDF in batch mode
James
Hi All,
I am having problems with running my job in batch mode when i hook a udf to Fluent. Is there a way around this? What i have done is to use the compiled option to build the udf library and at the inlet and out of my boundary, i am using a udf. I am able to run it when i run fluent interactively. When i submit to the cluster, i get the following error message:
Opening library "libudf"... Primitive Error at Node 0: open_udf_library: No such file or directory error: executing task of job 783222 failed: error: executing task of job 783222 failed: error: executing task of job 783222 failed: error: executing task of job 783222 failed:
Is there anything i can do to have this job run in batch mode?
My job is suppose to run on two processors and so i suspect i need to parallelize my udf? or i have to do something about the read/write commands in my job file? Any suggestions on how to fix this problem will be appreciated.
Thanks in advance.
James
problem using property udfs in parallel mode EllenW FLUENT 0 June 23, 2009 17:18
UDF compiling problem in Flient 6.3 jeevan kumar FLUENT 2 February 25, 2009 00:43
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 07:52
fluent stops batch mode on error Ralf Schmidt FLUENT 1 March 1, 2008 10:35
UDF hook problem in command line mode. Benlong FLUENT 1 November 12, 2007 14:45
