June 10, 2006, 08:31 |
probleme with gambit
i have this geometry : small cylindre connected with big rectangle volume by splitting ,can i mesh small cylindre with different interval size then rectangle volume .
please give me the procedure for how to mesh my geometry chankhar |
June 10, 2006, 12:22 |
Re: probleme with gambit
yes you can, you are supposed to use mesh edge not mesh volume.
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing | David-CFD | ANSYS Meshing & Geometry | 1 | April 1, 2011 05:22 |
Gambit help: Cube inside cube | Jack Martinez | FLUENT | 13 | August 11, 2010 06:29 |
Gambit 2.3.16, Xming or Exceed...HELP! | bambam3417 | FLUENT | 10 | May 7, 2010 12:39 |
Gambit -dev X11 doesn't work | Ervin Amet | FLUENT | 0 | October 28, 2007 08:33 |
probleme in mesh with gambit urgent | chankhar | FLUENT | 1 | June 9, 2006 13:12 |
