how to plot velocity profile at any x-location
Old   June 12, 2006, 09:24
Default how to plot velocity profile at any x-location
Brendan
I am trying to design a contraction for a wind tunnel and I wish to look at the velocity profile at several x-positions along the contraction. I can not figure out how to plot a profile for a selected x-position. I can only plot the profiles at the boundary conditions I have defined such as the inlet, outlet, etc.
Old   June 12, 2006, 10:01
Default Re: how to plot velocity profile at any x-location
clem
If your geometry is 2d you can try to place isosurfaces from x-coordinates. Otherwise, you can buildline/rake. Enter the coordinate of two vertexes and plot on the line you just create.
Old   June 12, 2006, 12:12
mohmed
create plane if you have a geometry in 3d and you can display contours at this plane
Old   June 13, 2006, 01:32
Sahin
do the following; 1) locate a point/point surface on the location 2) with help of coordinates or surface tool (selecting th epoint through mouse) 2) read the profile on this surface
UDF inlet velocity profile mismatch with Fluent ChristineL Fluent UDF and Scheme Programming 15 November 25, 2016 06:45
Plot velocity profile at different position AirS Main CFD Forum 2 December 3, 2010 06:03
Plot a graph of velocity wanie OpenFOAM Running, Solving & CFD 5 December 17, 2009 17:48
Plot a graph of velocity & boundary condition problem wanie Fluent UDF and Scheme Programming 0 December 11, 2009 10:40
particle velocity and velocity profile HGG FLUENT 2 June 10, 2001 16:32
