good cold flow results but problem with hot flow,. |
June 13, 2006, 11:08 |
Hello Friends,..
i have got good results in agreement with the experimental values for cold flow analyis,... but when am starting combustion on the same geometry,... am getting negative pressures at the throat of the inlet and oulet nozzles of the combustion chamber,... this negetive pressures is not dying down but going on increasing,... am doing non-premixed combustion using mixture fraction/pdf model,... am unable to locate where the problem lies,.. is it in the pre-pdf or any where else,... My inlet boundry conditions for hotflow are Pressure inlet : 60bar at inlet nozzle Pressure oulet : 0bar (i.e atmospheric pressure ) at outlet nozzle Wall Temperature : 500K Operating pressure is 0 pa Please help me in solving my problem,.. Thanks regards,.. Rams -------------------------------------------------------------------------------- |
Flow not moving - Supersonic/Initial Pressure problem? | shankara.2 | FLUENT | 0 | June 9, 2009 20:49 |
LES of highly heated pipe flow - incorrect results | MichalH | FLUENT | 3 | June 3, 2009 05:00 |
transient compressible flow problem (urgent plz) | jehanzeb | FLUENT | 5 | August 3, 2004 08:04 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
computation about flow around a yawed cone | Tylor Xie | Main CFD Forum | 0 | June 9, 1999 07:33 |
