June 19, 2006, 04:33 |
Time dependent boundary conditions
Hi, I'm sorry to asked that because it seemed obvious for me but finally I didn't manage to do that. How ca I define a time dependent boudary conditions (for exemple a variable speed on the inlet). Thanks for your help. Renaud
June 19, 2006, 21:17 |
Re: Time dependent boundary conditions
You have to use the UDF DEFINE_PROFILE. Check in the UDF manual, chapter 12 ("sample problems"), your case is already done. Cheers, Fabrice. |
June 21, 2006, 19:44 |
You could just define a mass flux profile. No UDF needed. \help\html\ug\node176.htm , \help\html\ug\node267.htm
Residence Time Distribution with Periodic Boundary Conditions | sanjose | FLUENT | 1 | September 7, 2016 04:13 |
Implementation of boundary conditions for FVM | Tom | Main CFD Forum | 7 | August 26, 2014 05:58 |
CFX does not continue | Shafiul | CFX | 10 | February 17, 2011 07:57 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
