HELP: udf compiling mistake
Old   June 25, 2006, 08:39
Default HELP: udf compiling mistake
Siyu
udf userguide (eg. 4.6.12)
when I compiled the udf, mistake occured and libudf.dll could not be built. Who can tell me what wrong with it?
..\..\src\condense.c(64) : warning C4047: 'initializing' : 'struct thread_struct *' differs in levels of indirection from 'int ' # Generating udf_names.c because of makefile condense.obj udf_names.c # Linking libudf.dll because of makefile user_nt.udf udf_names.obj condense.obj Microsoft (R) Incremental Linker Version 6.00.8447 Copyright (C) Microsoft Corp 1992-1998. All rights reserved.
Creating library libudf.lib and object libudf.exp condense.obj : error LNK2001: unresolved external symbol _P_THREAD libudf.dll : fatal error LNK1120: 1 unresolved externals
DEFINE_DPM_LAW(condenshumidlaw,p,coupled) { real area; real mp_dot; cell_t c = P_CELL(p); /* Get Cell and Thread from */ Thread *t = P_THREAD(p); /* Particle Structure using new macros*/
(this is the warning line.)
area = 4.0* M_PI * (P_DIAM(p)*P_DIAM(p));
/* Note This law only used if Humidity > 1.0 so mp_dot always positive*/ mp_dot = CONDENS*sqrt(area)*(myHumidity(c,t)-1.0);
if(mp_dot>0.0) {
P_MASS(p) = P_MASS(p) + mp_dot*P_DT(p);
P_DIAM(p) = pow(6.0*P_MASS(p)/(P_RHO(p)* M_PI), 1./3.);
P_T(p)=C_T(c,t); /* Assume condensing particle is in thermal
equilibrium with fluid in cell */ }
Old   June 26, 2006, 06:43
Default Re: HELP: udf compiling mistake
web yin
what you did is the interpreted file ,not compiled files ,there are some differnces between them
Old   June 26, 2006, 06:58
Siyu
Thank you. I finally found the wrong. The right marco is "P_CELL_THREAD" not the "P_thread".
compiling my Udf noa Fluent UDF and Scheme Programming 8 November 7, 2018 20:08
Compiling UDF on a cluster Adya FLUENT 1 December 14, 2009 11:30
UDF compiling problem in Flient 6.3 jeevan kumar FLUENT 2 February 25, 2009 00:43
udf compiling problem akr FLUENT 3 August 22, 2007 07:14
On Compiling a UDF David Chabot FLUENT 5 May 20, 2005 09:13
