"Clearing partially read grid"
Old   June 22, 2006, 15:45
Default "Clearing partially read grid"
Peter
I've got a car mesh with 1.2 Million cells. While loeading it in Fluent the error below occurs. It's weird because i computed with the same mesh once. Any idea what might be wrong? Thanks in advance
Building...
grid, face[22061]->node0[0] out of range (0<node<1135616). Error: Build_Grid: grid error.
Clearing partially read grid.
Old   June 23, 2006, 10:35
Default Re: "Clearing partially read grid"
Aidan
I have had similar problems before. Are you using windows or Linux OS?
Old   June 23, 2006, 11:00
Peter
In both cases (Windows, Suse) i get the same problem. After exporting from Gambit Fluent declines to accept. But i computed with the same geometry before. So i don't know the reason for that.
MapFields to New Grid For Extreme Grid Deformations due to Body Motion albcem OpenFOAM 0 May 5, 2009 14:17
Exporting ICEM Tetra Grid to Fluent with Hexa-Core Tim FLUENT 2 August 30, 2007 07:16
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 11:18
How to Read Structured Grid in Fluent5? caihu Main CFD Forum 1 October 19, 1999 23:26
