Turbulence intensity BC
Old   June 28, 2006, 10:11
Default Turbulence intensity BC
Ralf Schmidt
Hi!
I have a simple geometry (free stream around a cylinder). The inlet BC is vel.inlet with turbulence parameters are turbulence intensity and hydraulic diameter (diameter of the cylinder).
Now when I plot the values of turbulence intensity at the inlet, they are 1. not all the same over the face (they vary about +- 5%) and 2. slightly lower (about 10%) than the values I set as BC. What happend?? The reference velocity is the free stream vel.
Any Idea?
Ralf
Old   June 29, 2006, 18:16
Default Re: Turbulence intensity BC
freeman
you might want to look up in the USER manual in that regards. Remember that, the turb. intensity at the inlet depends on Ub or tke. so if the vel. is not uniformaly distributed then you wouldn't expect the intensity to be uniform. what I'll suggest is that plot the vel, tke and based on that you tell what's going on.
all the best
Old   June 30, 2006, 01:02
Ralf Schmidt
Thanks for reply!
I checked the points you mentioned:
there is a constant inlet velocity BC of 21 m/s BUT in the plot, the vel. is NOT uniformaly distributed, it is fluctuating about +-0.005% of the inlet vel.
How could that happend?? Because of mass balance? I do a incompressible calculation.
The Turbulence kinetic energy, turb. viscosity, omega and the turbulence intensity have the same fluctuations. BUT they are much larger!!
How could a vel. fluctuation of 0.009% cause a Tu.Intensity fluctuation of about 5% ???
What happend?
Ralf
Old   June 30, 2006, 04:17
freeman
if I may ask, what is the shape of the inlet, circular or rect?
anyway, to check if you're doing right thing, check your mass balance to see if mass_in=mass_out through the report menu. I think what happened was tha if you specified normal velocity at surface, Fluent interpolate it over the surface by dividing it according to the number of nodes so you wouldn't expect all the nodes to have the same values, however the mass-flow will be correct and the total integration of the vel will be equal to what you specified. You could cross check that through that through the 'REPORT menu' and also the user manual.
as for higher variations in the turb quantities are obvious, since they are in higher order of the vel. eg. tke=(...)vel^2. That's not a problem.
I hope that works. if I may ask, how are the general results look like? outlet plane results? are you comparing with expt or what? if you do, how did it deviate from it?
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 14:18
Question on Turbulence Intensity Eric FLUENT 1 March 7, 2012 04:30
About Turbulence Intensity (Pipe flow assimilated) gRomK13 Main CFD Forum 1 July 10, 2009 03:11
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
