Hi all
may be this is a basic question... What is the need to devide a complex volume into small sub volumes before meshing, what are the advantages. please let me know clearly, thanks in advance |
Actually the method which u imply for solving CFD requires you to make a small volumes near the important regions because then you can actually obtain or capture small scales especially close to the wall or also the accurate value of the variable you are interested in. By breaking the larger volume into smaller you also aviod false result with the discritization scheme you are using .
I hope i have answered your doubts have fun |
How to solver coupled transport equations | chris1980 | OpenFOAM Running, Solving & CFD | 8 | October 29, 2019 07:15 |
General question what fluid properties do you use | harly | OpenFOAM Running, Solving & CFD | 0 | November 18, 2008 15:38 |
A general C question | niklas | OpenFOAM | 1 | September 8, 2008 11:38 |
Poisson Solver question | Suresh | Main CFD Forum | 3 | August 12, 2005 04:37 |
question | K.L.Huang | Siemens | 1 | March 29, 2000 04:57 |
