smooth interface with VOF models
Old   June 21, 2012, 18:58
Default smooth interface with VOF models
navid
ndabir is on a distinguished road
I am simulating bubble collapse close to a wall. when I want to patch pressure and temperature to the inside of bubble, I realize that the bubble interface is sharp (although I have a fine mesh). Does anybody know what can I do to smooth the interface? I read somewhere in other posts that I can use TUI command: rpsetvar 'patch/vof? #t
I don't know where to use this command. Can anybody help me please.
ndabir is offline   Reply With Quote
Old   June 25, 2012, 04:56
Elias Paez
sicfred is on a distinguished road
Are you using the vof explicit method with geo-recronstuction?, because, if you are using this method, i think your mesh is not fine enough.
sicfred is offline   Reply With Quote
Old   July 6, 2012, 12:35
navid
Yes I am using that method. But I have even refined the mesh near and inside the bubble (around 0.5 million nodes) but still can get smooth pressure contours. any idea how fine should I make the mesh?
VOF interface compression and mesh size idrama OpenFOAM 1 September 26, 2010 06:36
VOF - interFoam - strafitied Flow - bug in shear stress continuity at interface AnjaMiehe OpenFOAM Bugs 0 December 17, 2009 05:46
VoF Interface definition Anto Siemens 2 January 19, 2009 05:05
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
VOF model and interface! Adel Ataki FLUENT 2 March 11, 2002 22:04
