FIDAP and temperature dependent mat properties |
July 11, 2006, 13:45 |
I am running a 2D problem which has solid and fluid elements. Fluid has a free surface. This is a simple represantation of a laser welding problem. I can see the temperature contours and the velocity fields in the melt pool if I use constant material properties. When I try to use temperature dependent mat properties (visc(curve=2) etc.), it doesnt work. In the Fipost it says only mesh could be shown. I am new to FIDAP so any help will be appreciated. Regards, Cumali |
FIDAP and temp dependent mat properties PLS HELP!! | SEMETAY | FLUENT | 1 | July 14, 2006 02:04 |
Phase Change+strong Marangoni, FIDAP - need a help | Vitaliy Pavlyk | FLUENT | 0 | July 31, 2001 05:12 |
FIDAP - Lubrication | Barman Tambunan | FLUENT | 0 | March 25, 2001 19:43 |
Variable Density - Free Surface with FIDAP | Vitaliy Pavlyk | FLUENT | 7 | May 2, 2000 15:56 |
