Pressure outlet
Old   July 11, 2006, 23:01
Default Pressure outlet
Vidya
I want to retain my outlet Boundary Condition to be specified as being at atmospheric pressure. For this, I chose the face that is to be the outlet, went to BC in Fluent, selected the PRESSURE OUTLET option, and just selected OK to whatever the default was. Isn't the default set to atmospheric pressure? then why does Fluent give error messages?
Since the deafult gage pressure is zero, the pressure is atmospheric. So what could be the problem?
Thanks.
Old   July 12, 2006, 13:37
Default Re: Pressure outlet
Vivek
There shouldn't be any problem. What error message did u get?
Old   July 12, 2006, 14:11
Vidya
It just gave a value of zero velocity at every point in the flow domain, which is absolutely meaningless. Also, all other parameters like pressure etc were either zero, when it actually shouldn't be, or sometimes goes to zero, which is again absurd.
Will specifying pressures at both the inlet and outlet help solve the problem?
Thanks
Old   July 12, 2006, 15:08
Vivek
whats ur inlet boundary condition now? what problem are you trying to solve?
Old   July 12, 2006, 17:10
Vidya Raja
I gave a steady input velocity of 0.175 m/s at the inlet. I want to retain the outlet at atmospheric pressure. The flow is laminar, and I'm trying to model blood flow.
Is it possible to specify pressure BCs at both inlet and outlet? Then the inlet pressure is very small..... about 1.5 mm Hg. That's why I want to use the velocity at the inlet. I also have to run the case using an unsteady velocity.
Old   July 13, 2006, 12:00
Vivek
You could do it either way. There shouldn't be any problem at all. Just make sure if there is an internal suface which you forgot to change from the default wall boundary condition. Its typically the reason for zero velocities
Old   July 13, 2006, 13:20
Vidya Raja
I made that change, but the residuals never converge. However, the trends for all the residuals (continuity, x,y,z velocities) appears to be the same. Even after 17,000 iterations, the solution doesn't converge.
What could be wrong now?
Thanks, Vidya
Problems in pressure when using mass flow rate outlet rafiktharwat CFX 11 January 2, 2014 17:21
pressure oscillation near pressure outlet boundary kino Main CFD Forum 5 April 13, 2011 11:03
Pressure Outlet setting CoG STAR-CCM+ 4 June 9, 2010 21:47
what actually is the 'zero pressure outlet b. c.' hwe001 CFX 4 June 7, 2010 15:22
Backflow occuring at a pressure outlet? Dave FLUENT 1 August 12, 2004 17:39
