Unreal temperature in conjugate heat transfer CFD
Like Tree1Likes
  • 1 Post By Chandra Murthy
Old   August 8, 2006, 11:39
Default Unreal temperature in conjugate heat transfer CFD
joe
I am solving a conjugate heat transfer flow problem without heat generation. A heat exchanger pipe keeps showing some unreal temperature at a few cells in solid domain. The convergence of the problem looks fine. Anyone can give me some suggestions? Thanks
Joe
Old   August 9, 2006, 09:23
Default Re: Unreal temperature in conjugate heat transfer
Chandra Murthy
For CHT problems..one has to use...double precision solver, 2nd order dicretization and close control on near wall treatment..afterall the boundary layer prediction matters in CHT...if you have followed all the above..and still getting the same problem...probably mesh is the culprit...check your problem...
lhxy0301 likes this.
Conjugate heat transfer: coupled wall temperature Sarah FLUENT 7 August 12, 2013 22:36
Conjugate heat transfer, thermal boundary conditions Sarah Main CFD Forum 1 April 7, 2010 07:20
Conjugate heat transfer problem hvem10 FLUENT 2 October 29, 2009 17:31
Conjugate heat transfer with periodic boundaries Suresh FLUENT 0 February 23, 2009 09:51
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
