Transient oscillatory flow
Old   August 30, 2006, 09:25
Default Transient oscillatory flow
yms
Hello everybody,
I am trying now to solve a simplified thermoacoustic problem using Fluent6.1. It is simply an oscillatory flow problem inside a channel, with transient pressure boundry conditons
time:0-->15.71s (period of one cycle is 1.571 s).
I am using the segregated solver with 2nd order implicit unsteady formulation. I got converged solution, with the same trend as the analytical solution but with some differences. If i used a time step of 0.01 s, i noticed that fluent will give me a very good agreement with analytical solution but for a time 0.03 sec earlier than that of the analytical solution. that is analyt sol at t=14.3 is the same as that of fluent but at t=14.27 .
I solved the same problem with Comsol Multiphysics (Femlab 3.2) and it gave me the same results as analyt sol with no time lag.
I also noticed that coupled solver doesnt work for this problem ( iam using viscous incompressible fluid) ??!!
Any suggestions, to solve the problem??!!
Your help is so much appreciated.
Best regards, YMS
Steady state vs. mean transient analysis of flow behind a circular cylinder Heini Main CFD Forum 1 June 9, 2011 06:47
Transient heat flow saisanthoshm88 FloEFD, FloWorks & FloTHERM 3 June 7, 2011 09:13
transient compressible flow simulation-urgent JSM FLUENT 0 April 26, 2007 01:51
periodic and transient flow Somchai FLUENT 2 March 26, 2007 22:37
2D Transient flow using Fidap Young FLUENT 1 July 2, 2004 12:02
